Seized Screw on cra...
Seized Screw on crank removal
[#12436433]
My normal tactic - bike against wall, both brakes on, stand on pedal with one foot and long breaker bar with other and bouncing my 15 stone - ain’t shifting it
Any other bright ideas??!
Posted : 23/06/2022 8:42 pm
One last go and shifted the fu@@er….
Posted : 23/06/2022 8:50 pm
Dub bottom bracket by any chance??
Posted : 23/06/2022 8:51 pm
Gonna be that or GXP
Posted : 23/06/2022 8:54 pm
Yup - DUB
Posted : 23/06/2022 9:27 pm
Yeah, there isn't much that can't be defeated with a cheater-bar. Make sure the key/head is firmly seated though before applying massive torque. Maybe soak in penetrating fluid too for half an hr. When I ran instrumentation offshore I often used vibration to help back-off 'seized' components too, but with small screws this is probably moot because cheater-bar torque will be enough or it will twist-off the head/screw anyway.
Posted : 23/06/2022 9:49 pm
I always imagine a guy in each factory from SRAM with arms like tree trunks fitting all these bottom brackets.
Posted : 24/06/2022 10:22 am
I had a tie strap and a mate holding the bike and a 1/2 breaker bar....
Went with a right crack
Posted : 24/06/2022 10:33 am
Three hex bit sockets later and mine still hasn't moved.
Posted : 24/06/2022 11:33 am
I once put a shimano square taper bb in to a ti frame and forgot to add the anti seize. It wasnt keen on coming out, made horrific shrieking noises, snapping round a little bit at a time, and i thought the frame bb shell was going to shear off.
Posted : 24/06/2022 11:40 am
