Second wheelset for...
[Closed] Second wheelset for a 27+
 LMT
[#8135921]
I know I need a 110mm boost for the front wheel, but what do I need for the back? I've seen 148mm, hub but they come in shimano or sram whats the difference? and how do I know what mine is currently as it doesn't say on the spec or on the bike? its a speshi fuse. I'm guessing the only difference is if I plan to put a shimano or sram cassette on it?
Posted : 30/10/2016 9:51 pm
It will need a boost hub - 148mm. Do you have the spec sheet there? If it's a 10-42 cassette, it's definitely a SRAM and will need an XD driver (SRAM) hub.
Posted : 30/10/2016 9:52 pm
 LMT
Yep that's the one.
Posted : 30/10/2016 9:56 pm
I think it's a Fuse Expert you have?
Drivetrain: The drivetrain is funky mix, with Specialized Stout cranks with a 30-tooth narrow-wide chain ring matched to [b]a Sun Race 11-40 10-speed cassette[/b]. It’s all hooked up to a new SRAM GX derailleur and X9 shifter.
If that's the case then it's a standard freehub, not an XD.
 LMT
So a 148mm shimano then? Stick a shimano 10 speed cassette on it.
Posted : 30/10/2016 10:20 pm
Yep. Any 10-speed cassette will do, though you'll not get 11-40 like the Sunrace. That might affect chain length and mech position. For simplicity (and to ensure no differential chain/mech wear issues) I'd probably just swap the cassette over when changing the wheel. It's a two-minute job with the right tools.
Posted : 30/10/2016 10:23 pm
 LMT
I've already got a spare cassette, I know Cannock eats them for breakfast! Just about to order the wheels, I've got the tyres and tubes, quite fancy some hope hubs on this set.
Posted : 30/10/2016 10:41 pm
Also expect to fiddle with caliper alignment when changing wheels - often just a mm or so.
Posted : 30/10/2016 10:47 pm
