Seatposts - questio...
[Closed] Seatposts - questions in search of answers, EA30, EA50, NC-17 etc please.
[#831483]
Righto, need a 27.2 post for my Dialled Bikes Alpine with a bit of lay back ie 10 - 15mm or so.
Don't want a layback Thomson as i don't think they look right.
BUT, I want one that will last in terms of finish like a Thomson.
any recommendations?
also whats the difference between EA30 and EA50 hardly any weight as far as I can see, so is the EA50 stronger?
and to finish what are these like?
NC-17 Empire post, they are only £24
Posted : 01/09/2009 8:47 pm
Think they look pretty good, myself.
http://www.chainreactioncycles.com/Models.aspx?ModelID=8569
Higher the number for Easton stuff, the better it is. If its not weight, it might be strength. Or maybe that marginal weight difference is the only difference.
Posted : 01/09/2009 8:58 pm
Same bike, same dilemma.!
Solved with NC17, working well, finish still intact after mudfests of the summer!
Had EA50 and Thomson and finish wasn`t any better on either of those
Posted : 01/09/2009 9:04 pm
Got the NC-17 here. As good as anything else I've used.
Posted : 01/09/2009 9:08 pm
got an nc-17. Black finish wears more than a Thomson when you move it up and down, but probably less than an easton. Its also abour 230g for a 30.9 * 400 which is very light.
can't fault it other than that
Posted : 01/09/2009 9:37 pm
EA70
Posted : 01/09/2009 9:42 pm
how strong is nc17 post then ??
cheers
steve
Posted : 01/09/2009 10:21 pm
I've decided on a controltech - 20mm setback at the head (as opposed to bent post), 400mm long and pretty light.
Posted : 01/09/2009 10:26 pm
at 3mm thick I think they are built like a brick out house.
looks like the one to try i'm thinking
Posted : 01/09/2009 10:27 pm
HIJACK: Lift to STW ride on Sunday do you have room?
Ta
Edit - I had decided but now I haven't!
Posted : 01/09/2009 10:28 pm
go on then why it's you.
I wouldn't do it for anybody you know.
whats the route, do we know yet?
Posted : 01/09/2009 10:29 pm
will e-mail Graham direct but I know nothing other start and end @ Lee Quarry.
Cheers for lift
seeing as you are in such a good mood (that night away from kids ?) I will get you to finish my Cutter LED at the end then 😉
Posted : 01/09/2009 10:48 pm
will do.
might be better if you pop over one night, rather than trying to sort it after a 30 mile ride. I couldn't stay awake after the last one, let alone solder
Posted : 02/09/2009 7:41 am
Vortexracing - Member
I thought so too but snapped mine. It was welded into a broken frame as a temperoary fix though and lasted about 3 months before snapping, about twice as long I expected 🙂 The head design is reasonable (much better than a single bolt) but not a patch on race face ones.
Posted : 02/09/2009 8:09 am
If you want a long lasting cosmetic finish, then the EA70 isn't really up to it. I've had mine for a few rides and the anodising is well worn already. It's a great piece of kit otherwise.
Posted : 02/09/2009 8:42 am
