I need to get a seatpost out of a frame, its a aluminum frame and a steel seatpost or the other way round,, anyway ideas appeciated, ideally to save both the frame and the post?
Posted : 24/04/2017 7:04 pm
Remove the wheels. Put the seat post in a vice and use the frame as leverage. Will probably kill the seatpost
Posted : 24/04/2017 7:34 pm
If all else fails
Theseatpostman.com
Posted : 24/04/2017 7:35 pm
If it's a steel frame, then remove the bottom bracket, bung up the bottom bracket hole with something (inner tube), and then pour in hot sodium hydroxide (caustic soda, about £1.50 from a garden centre) and leave overnight, occasionally stirring.
Wear rubber gloves and goggles if you value your good looks and eyesight.
Post up video when you're done!
Posted : 24/04/2017 7:50 pm
