Having just read the recent thread about dropper seatposts (which I intend to get one of) and the use of shims I have just had a thought.
If you use a shim am I right in saying that the effective insertion is only the length of the shim?
I'm sure I've used a fairly short shim on a seatpost before which i'm guessing is bad news.
Posted : 01/06/2012 8:02 am
yes, only the length of the shim.
as long as the shim goes a few cm below the top tube/seat tube/seat stay junction you should be ok.
Posted : 01/06/2012 8:04 am
Yup - most commercial shims will extend for several inches below the clamp IME 🙂
Posted : 01/06/2012 10:06 am
USE shims are 100mm long IIRC
Posted : 01/06/2012 10:57 am
