Seat tube compressi...
[Closed] Seat tube compression slot cracks in steel frame...thoughts?
[#7991499]
Just noticed these:
Should I drill the ends to stop propagation or just MTFU and get riding?
STW-hive-mind do your work....
Posted : 10/08/2016 7:37 am
Are you sure they're not just in the paint - can you see them on the inside?
Posted : 10/08/2016 7:41 am
Yep, not just the paint as I can see the cracks on the inside
Posted : 10/08/2016 7:49 am
Don't drill - it really needs a proper repair. A bodge that works is to braze a washer over the hole, then cut the slot again. But it really needs the attention of a framebuilder.
Posted : 10/08/2016 7:52 am
And a correctly fitting seat post.
Posted : 10/08/2016 9:46 am
Is that slot in the side of the seat tube, rather than front or rear?
Posted : 10/08/2016 10:20 am
Thanks all. Sadly I have only recently acquired the frame and not had a chance to ride it even!
The slot is side.
Brant - is it likely a post too small has been used?
Posted : 10/08/2016 11:20 am
Any recommendations for a frame builder or repair South Birmingham/Coventry way?
Posted : 10/08/2016 11:24 am
Yes. Too small post would cause "gathering" and give this result.
Posted : 10/08/2016 2:43 pm
The slot is side.
Pace?
looking at the colour, maybe a RC129...?
Posted : 10/08/2016 3:19 pm
I wouldn't have thought a side facing slot would be the best idea anyway.
Posted : 10/08/2016 4:57 pm
I had that on steel frame but worse so had that bit cut off and a braze on collar with a bolt instead Argos in Brizzle did it for me
Posted : 10/08/2016 5:11 pm
