Hi all,
I've got a Bfe with RS Sektor's on it, my problem is that even at the 120mm travel setting my saddle points up a little. I bought a cheap 400mm seatpost (Funn iirc) when I built the bike up, but it doesn't adjust enough to get the nose level.
What does everyone else use to avoid this?
Matt
I have a raceface respond on my Bfe with 140mm revs and it is fine.
You sure the post is the right way round?
Thanks cdoc, yep, it's defo the right way round, and reversing it doesn't help. it just doesnt have the angle adjustment. I'll have a look at the Respond then.
Cheers.
Anyone riding anything else?
I've got a reverb on mine.
Check if the post or clamp is facing the right way.. I made the mistake on my reverb 😳
Crank Bros Cobalt on mine, no problems with the seat with 150mm forks.
Reverb and Thomson used on mine. Both have enough tilt either way.
KS 950 and some cheap old Bonty on mine. Surprised any post would give the problem you describe on a BFe.
Thomson was rubbish on mine, kept slipping.
Kronolog on mine
