Seat pin seized in ...
[Closed] Seat pin seized in frame
[#6465128]
Time to drag my winter bike out for a bit of a fettling unfortunately the seat pin is solid in the frame (One One 456) I know, I know I should have stripped and greased it BEFORE putting it away in the spring. Any tips for freeing up alloy seat post stuck in a steel frame? Tried WD40 and hitting it with a hammer and a piece of wood but she ain't budgin"
Posted : 06/09/2014 10:20 am
Probably chemically fused now. Check out caustic soda use for a seat post.
Posted : 06/09/2014 10:35 am
Plus Gas? I will give that a go, had not thought about taking out BB, good idea, thanks!
Posted : 06/09/2014 11:06 am
Or have it melted out as part of a respray....
Posted : 06/09/2014 11:20 am
Plus gas, hold seatpost tightly in a vice, turn frame
Posted : 06/09/2014 11:27 am
Coke works too, pour it into the frame from the BB, leave overnight...post in a vice then use the frame as a lever and turn...
Posted : 06/09/2014 4:48 pm
 JoeG
[url= http://sheldonbrown.com/stuck-seatposts.html ]http://sheldonbrown.com/stuck-seatposts.html[/url]
Posted : 06/09/2014 10:42 pm
Genuine full fat Coke a Cola. Honestly.
Posted : 06/09/2014 11:10 pm
Accept the post is a write off and put it in a vice and twist the frame around it following liberal application of oil and if you're a believer prior to that, the coke or caustic soda tricks. Should easily do the trick.
Did this on a Ti frame/ali post combo a few weeks ago for my next door neighbour and all was fine.
Posted : 06/09/2014 11:57 pm
Strip frame, place frame bb up with seatpost clamp in secure vise, pour/spray [i]plus gas[/i] down bb or bottle tube bosses every few hours when possible, leave 24hrs and grab frame at head tube/seat stays and crack off the seat tube bond.
Posted : 07/09/2014 12:00 am
OK good advice guys, I still can't budge it so off to a mates who has a vice and try the twisting thing. Coca Cola? Really? May as well give it a go as well...
Posted : 07/09/2014 10:44 am
Posted : 07/09/2014 3:17 pm
Getting liquid to penetrate from the top isn't easy (even if the seatpost wasn't sealed in, it'd still rather roll off the side thna down any gap). But turning the bike upside down and pouring in from the BB gives it nowhere to go but past the seatpost (well, unless there are other holes). Remember it'll make a bloody mess though.
Posted : 07/09/2014 3:46 pm
