Does anyone know of any alternative to the genuine huske through axle adaptors? ie cheaper?! i've a bomber 3 rack and would need at least 2 sets of adaptors. That's roughly £50.
i do have a blok pod mount and adaptors on my talon, but these adaptors don't fit the huske mount
Rockbros do a rip-off version of Seasucker racks and have adaptors for cheap... might be worth trying.
I 3D printed some 15mm and some Boost adaptors for my cheapy knock off job, there's models galore on thingiverse if you have/know someone with a printer.
Edit:
These the thing you're after?
https://www.thingiverse.com/thing:4550292
I could probably knock you up a couple of sets and post them (timescales/quality not guaranteed 🙂 )
PM me if you would like me to...
I've got some ZTTO mounts in my van with adapters and a Talon with a HUSKE mount; let me dig them both out and see if there's any cross compatibility - even if it's just the ZTTO mounts using the same mount points might help; they are only £20 / pair
Ok @christophert21 - The adapters are not cross compatible. However; the ZTTO mounts have the same fixing centres as the seasucker mounts; so you could simply replace the entire mount - £25 for two sets from Amazon - ZTTO Mounts here on Amazon
Or you could buy them direct from AliExpress for a bit less if you don't mind waiting. Ali Express here
FWIW the pair I got from both places; are identical and were in identical shipping bags; the Amazon ones were clearly just imported and sold on 😀
Good to know they are the same fixing centres. Literally just bought some sea sucker versions today, will buy the Ztto ones now and return the others.
