Searching in vain f...
[Closed] Searching in vain for a Single Speed Chainring 32T 5 Hole 110 BCD
 sp
[#5806335]
Have been Googling without success for a reasonably priced 32T 5 hole 110 BCD track chainring thats unramped and no pins for a single speed project I have underway. If anyone can point me in the right direction then that would be great.
Posted : 29/12/2013 5:38 pm
BETD Goldtec DH ring
http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=33&Name=Goldtec+Chainrings
bottom of page, £20.
Posted : 29/12/2013 5:42 pm
Fairly confident the smallest ring its possible to get for a 110 BCD is 33T, made by Specialites TA.
Posted : 29/12/2013 6:21 pm
I thought it was 34T but no way can you get a 32T on there.
Posted : 29/12/2013 6:51 pm
34t is the most commonly available, but the TA 33t does work. OP, I have a TA 33t ring, no ramps or pins, used for one cross race on a SS. Yours for £19 posted?
Posted : 29/12/2013 6:53 pm
Blackspire veloce uno?
Posted : 29/12/2013 7:36 pm
 sp
Thanks folks for your help, I've gone for the BETD 32T as it works well with spare cogs I have lying around.
umop3pisdn thank you for the offer.
Posted : 29/12/2013 8:48 pm
You're welcome. I'd be interested to see it mounted, I didn't think you could go smaller than 33t without the chain fouling on the crank arms.
Posted : 29/12/2013 11:39 pm
Really want to see this mounted, pics when it arrives please! Would have thought a 32t 110 BCD will have the chain running on the mounting bolts.
Posted : 29/12/2013 11:47 pm
Be really interested to see this chainring.
I just overlaid a 5 bolt 32t ring (compact) with a standard 110 crank - the chain will definitely be running over the bolt heads. The only way I can think of making this work is to have a very thick ring to allow counterbores for the bolt heads and also to serve as a spacer on the crank spider side (otherwise the chain will also foul the spider arms).
Sounds more like a bug on the website ordering options (but interested to see if they have really made it work).
Posted : 30/12/2013 1:10 pm
