terrahawk - Member
Used to use Stans, thought it was ok but had to use loads of it.
How much do you stick in a 29er? I'm new to this lark. Just done my wife's rear (ooer) I used 40ml as per instructions. Doesn't seem like a lot.
2 scoops for my 29er which IIRC is around 50ml
1 scoop in my CX
3 scoops in b+ though I think that's probably overkill.
Stans here , tried [b]Goop [/b]once , bloody waste of money that was .
I’ve used stans for a while and as mentioned above i think the monsters have to do the tyre and how well its sealed to the. As had the same type of tyre on a different bike/rim and had monsters in 1 and not in the other. Same result happens with different tyres on the same rim.
But stans always works well and I the same liquid for 6 months
Doesn't stans also react with co2, if you use use canister to seat the tyre that might shorten the life.
I've been using Stans for years
I generally keep up with top ups
I fill by pulling a tyre side off a bit, inspect and deal with whatever I find
Works - I think I'll stick
Just got some schwalbe stuff (made by stans) cheaper and seems to work pretty good so far......
