Scott voltage or YT...
[Closed] Scott voltage or YT Noton as DIA bikes ...
[#5642871]
That's do it all!
Don't mind pedalling a 32lb bike uphill but geometry wise, are they ok ?
I'm tempted but before I splash any cash I thought I'd ask some perfect strangers for their opinion
Over to you now!!!
Posted : 28/10/2013 7:36 pm
Or not...as it seems! 🙂
Posted : 28/10/2013 9:13 pm
No idea on the Voltage but the Noton is hardwork uphill but great pointed down. Saying that if you're not in a rush to pedal back up then the Noton will do it. The geometry isn't the problem it's the weight but if you're not worried about that then the Noton is a very good value bike.
Posted : 28/10/2013 9:24 pm
there is one for sale here: http://www.pinkbike.com/buysell/1454774/
Posted : 28/10/2013 9:37 pm
Pedaling the voltage uphill is hard with a capital H. I run it with a reverb when it's not being uplifted which makes it acceptable.
Posted : 28/10/2013 9:52 pm
Torihada - is that due to weight or geometry? I'd had a 35lb Enduro that was ok uphill but after a few hours was a bit much. I'd be running it at 150 rear and 160 up front over here. It looks pretty adaptable and a reverb would be essential
Dango - that's the one I was speaking about
Posted : 28/10/2013 9:57 pm
There is no way I could ride my Voltage up any kind of hill - I'm 6ft, run a large and it's quite easy for my knees to hit the bars
Posted : 28/10/2013 10:04 pm
I'm a shortarse 5'8" and was quite surprised to see the top tube on a long being only half an inch longer than a medium Enduro
More concerned about weight really - rockshox vivid coil and 36 vans aren't light
Posted : 28/10/2013 10:17 pm
This summer in Chatel it was ok pedaling on the flat: on an incline it was do-able, even in pressure suit, FF & Leatt, but it's a real grind. I run 180mm single crown up front & 180 rear. It's slack & heavy, even with a ti-spring. To pedal it you'll really need a long seat tube: the Swiss lift guys bust my reverb and I had to use the post that came with the bike, pedaling was grim. It's all worth it for the DH stuff, then it comes alive.
Posted : 28/10/2013 10:29 pm
Cheers for that
Good to get some feedback. Thanks to all who replied
Posted : 28/10/2013 11:03 pm
If you are looking at YT bikes would you not be better considering a Wicked as your do it all bike? I've got the 650b version and, imo, it's more than capable for pretty much anything in the UK.
Posted : 29/10/2013 2:20 pm
