Hi, quick bit of advice from anyone who might know gratefully received...
Just building up a new DH race bike & I'm always keen to get more tyre on the ground so I bought a Hope 35W wheel set. I didn't realise quite how wide they were & now I'm not sure about it. One of my concerns is that I ran Procore last season & it was brilliant. Rim width on the Schwalbe site says min 23mm (no max mentioned) but I'm a bit concerned if the rims are deep enough & too wide for the inner chamber to grip on to. Don't really want to try it if I need to return the wheel.
Any thoughts?
I've not tried it myself on anything above 28mm internal width, but this was one of Schwalbe's comments in 2015:
"We've tested the Procore system on rims up to 40mm (outer width) and it does work. Wider than this is actually not tested since the 27+ trend is very new. However we see it very interesting to also use Procore on 27+ tires as they are used with a very low pressure. We’ll continue testing and will react, either with a further extension of the usage allowments or with a 27+ specific Procore version."
[url= https://www.syntace.com/index.cfm?pid=3&pk=3560 ]This is probably the rim[/url] they were talking about.
Cheers nach, much appreciated
I run procore on those Syntace W40 rims on my Liteville 601.
They're fantastic. You won't have any issue on a 35mm internal rim.
