Schwalbe on Light B...
[Closed] Schwalbe on Light Bicycle rims
[#7089771]
I have finally got my Light Bicycle 27mm hookless 29er rims built up. I have a new Schwalbe Rocket Ron and an older Ralph to fit. With 2 layers of Stans yellow tape, both types are so loose that there is no way of getting any type of seal for inflation. It makes me worry that even if I get them inflated, that they will not stay on while riding.
Since these tyres were tight on my crest rims, I wonder if any brands will actually fit.
Any advice out there?
Posted : 25/05/2015 10:17 pm
My experience with Schwalbe is that they seal ok if new but are a real PITA if they've been used. Same problem on Stans and Light Bicycle (hookless). On the other hand Maxxis go on fine even if previously used.
Posted : 25/05/2015 10:22 pm
The new Ron is extremely loose, I can remove and mount the tyre with no effort.
Posted : 25/05/2015 11:04 pm
 DT78
I've used Ron's and Ralph's witout issue so far, just fitted a new Ralph. I do haveto use a coke bottle compressor to get them inflated though, can't do it with a track pump
Posted : 25/05/2015 11:15 pm
I run Schwalbe NN and HD on LB 33mm hookless with no worries.
I did find I couldn't get a NN to go up on my sons bike but I just popped a tube in for the first ride then took it out and it went straight up.
Posted : 26/05/2015 7:20 am
 gee
Pull the sidewalks of the tyre onto the rim bed all the way round by pulling them apart, then use a compressor.
Works fine for a load of people I know with this combo.
Posted : 26/05/2015 7:26 am
new Thunder Burts went up no problem on my 27mm LB hookless rims.
Maybe just run a few more layers of tape, to aid inflation?
Posted : 26/05/2015 7:37 am
Yes. I found they went up with a track pump when new but very difficult when stretched a bit (2015 29er RoRo SS 2.25's) I loosely wrapped a couple of extra turns of electrical tape over the Stans yellow and pulled the beads out and that seemed to do the trick but they're right on the edge of not going up without a compressor / ghetto.
Posted : 26/05/2015 8:20 am
I stuck a tube in, and pumped them up to 50 psi, and they did not seat.
When I let them down again, the bead just came straight off.
Not very happy at the moment.
Posted : 26/05/2015 10:22 pm
 gee
Try squirting GT85 or similar on the beads to help them slip on and seat.
Posted : 27/05/2015 8:56 am
CO2 inflaters really help with this sort of thing
Posted : 27/05/2015 10:12 am
I also use washing up liquid and a little water instead if GT85, but I guess either will do...
Posted : 27/05/2015 10:13 am
Bontrager Flash Charger sorted it for me...
I had the same issue as others that a new tyre was great, but refitting older ones were very baggy, so you'd end up with extra tape, which you'd then have to remove if you got new tyres etc etc. you also end up with about 100g of tape on each wheel if you're not careful!
Posted : 27/05/2015 10:47 am
Well, I got them all inflated now. I ended up building a ghetto cola bottle inflator and they required 2 layers of stans tape.
Lots of laughing from the family while I was pumping like crazy to fill up the bottle before messing it up and having the tube fly off before it seated, but I eventually got there!
Posted : 01/06/2015 9:22 am
