Does anyone run there non UST Schwalbe Muddy Mary's tubeless? Was going to get one for the front to see me through the winter but have never had any luck with UST tyres from a couple of different company's so always just run standard tyres tubeless
I have never run Schwalbe tyres before so thought I better see if it works as I have had real problems with non UST Continentals having a very pourius sidewall.
Ran one on the rear, a right sod to get onto the bead. Ended up using a air line at work to get it to seat. Once on it took very little sealant to hold pressure.
Thanks for that, was it the folding or wire bead version? How did you find it for grip in mud and on wet rock?
I ghetto tubelessed a 2.35 folding muddy Mary on a mavic en321, went up & seated very easily just using a track pump, although put far too much sealant in it.
