Schraeder tubeless ...
[Closed] Schraeder tubeless valves?
[#6836222]
Do they still exist? Can't see any in stock anywhere and I'm a bit impatient. Took delivery of my Commencal Meta V4 rims are drilled for bloody Schrader and I've tried the decathlon tubeless valves in and whilst they deal with Stan's, I don't trust it!
Am I right in thinking I could ghetto with 24" tubes? Can I leave the Stans strip on too or is it best to remove it? Proper valves would be my favourite option though?
Ta,
Harry
Posted : 04/02/2015 8:22 pm
Just cut the valve out of an old tube leaving a bit of the tube around it to seal the hole.
Edit... do schrader still have a lock ring to keep them in place? Been years since I've used them. May be worth just getting some rim hole adapters instead.
Posted : 04/02/2015 8:26 pm
Nope they dont! I haven't used Schraeder for ever either. That's why I thought about using a 24" tube stretched around the 650b rim. Should hold it tight right?
Posted : 04/02/2015 8:30 pm
Oh, I didn't know rim hole adapters existed!
Posted : 04/02/2015 8:39 pm
I have Joe' s no flats tubeless schraeder valves in my rims, been using them for 18 months with stans fluid with no problems,
CRC sell them.
Edit: just looked, out of stock till the 9th Feb.
Posted : 04/02/2015 8:47 pm
The fat conical presta ones that superstar and wtb sell might do the job
Posted : 04/02/2015 8:48 pm
Schwalbe Schrader tubes have a threaded collar.
I used a 24" on the front of mine when I went ghetto tubeless 29+.
Works perfectly.
Should work just as well on s 27.5".
Posted : 04/02/2015 8:53 pm
i use the same as olderigetfasteriwas. changed mine from presta valves because they are nasty unnecessarily fiddly little pieces of crap.
used presta for years without problem then on a fatefull day at cannock them pesky presta's screwed me and ended up pushing back. will never fit em again 😀
Posted : 04/02/2015 10:37 pm
Schwalbe Schrader valves are threaded with a locking ring
Prestas are unnecessarily fiddley and complicated and offer no benefit over schraeder
Posted : 04/02/2015 10:52 pm
