Scandal V2 Headset ...
[Closed] Scandal V2 Headset size
[#5240446]
Hi all,
Does anyone know the correct Hope Headsets for the (Tapered) Scandal V2 headtube?
Cheers,
Rich
Posted : 12/06/2013 1:48 pm
 cp
what forks will you be using? straight or tapered?
Posted : 12/06/2013 1:49 pm
Ah - good point. I'm on straight at the moment (for the time being)...
Cheers,
Rich
Posted : 12/06/2013 2:20 pm
 cp
I gave up trying to work out which Hope headset cups to use so just went with a superstar headset which contains both races for straight and tapered. Bargain at £31
http://superstar.tibolts.co.uk/product_info.php?cPath=25&products_id=425
Posted : 12/06/2013 2:40 pm
Ta! Thanks for that. I'll have a look, though was after a black one (out of stock at the moment).
Cheers,
Rich
Posted : 12/06/2013 11:02 pm
Doesnt matter if you are running 1 1/8th or tapered as the Hope headset parts are the same. You just buy the reducer ring for the crown race if not running a tapered
If you look here
You need
Top: 2
Bottom: F
Straight 1 1/8th steerer you need HS136 too.
Or just buy the SS one.
Posted : 13/06/2013 1:53 am
Cheers Andy - that's great. Much appreciated.
Rich
Posted : 13/06/2013 8:42 am
I can concur with Andyl, as I have it written on a post-it note on my desk from when I sorted this a month ago....
Top:2
Bottom: F
You'll still need a top cap and bolt though...as the pick n' mix doesn't come with one
Posted : 13/06/2013 9:15 am
