Scandal Mk2 - 650b ...
[Closed] Scandal Mk2 - 650b tyre clearance
[#10812378]
I have a mk2 scandal, which is still all I need but only limited by rear tyre clearance.
Anyone running one 650b rather than 29" - if so, how big a tyre can you comfortably fit in.
Unless it's up to plus sizes is it worth doing or do you end up too small at the rear?
Posted : 14/09/2019 9:35 am
I don't know about the MK2, but it didn't work with my Mk1
[url= https://live.staticflickr.com/3705/18899519042_312e34fc78_b.jp g" target="_blank">https://live.staticflickr.com/3705/18899519042_312e34fc78_b.jp g"/> [/img][/url](Scandal - 650B/Hugo 52mm rim/WTB 2.8" tyre does not fit)
Maybe with a narrower rim, but then you lose the whole point of plus size, i.e. size.
Posted : 14/09/2019 10:12 am
 cp
Chainstays are *tight* on the scandal, MK1 and mk2, i don't think you'd even get a 27.5x 2.6 in.
Posted : 14/09/2019 10:44 am
Thanks both. 2.6" on 650b was all I had in mind but doesn't sound like it'll work. I'll just avoid the rock gardens!
Posted : 14/09/2019 1:23 pm
