SC Nomad mk 2 beari...
[Closed] SC Nomad mk 2 bearings???
[#3542879]
Does anyone know the bearing numbers for the lower and upper link on a Mk 2 Nomad ?
Posted : 09/01/2012 11:29 am
if your bearings are shot SC offer lifetime warranty on them, so i would phone Jungle they will send you some, well they did me anyway!
Posted : 09/01/2012 11:31 am
I just spoke to them and he was trying to sell me the pro pack for £117 which includes all the bearings, axles, seals, washers and bolts.
I've got some play in the lower link but i've managed to round off the bolt so i cant tell if its the bearings or just the axle.
Posted : 09/01/2012 12:05 pm
 Ewan
Try
and
Says it's for a BLT2 but I got the links from the embedding in the Nomad Mk2 bearing overhaul document ( http://www.santacruzmtb.com/nomad/#maintenance.php) - click on support and then maintenance.
Posted : 09/01/2012 2:57 pm
SBrock - Member
Is that true? On the web site they're charging £35 for the bearing kit for the mk2 (shock bushings £15, *each* on top).
Got play in my lower link and not sure what needs doing. Had the thing for 5 months and haven't bothered doing a re-grease yet (doesn't help I don't have the grease gun). Wondered it it just needs grease or if it's the bearings or something else.
Bolts are correct torque. No play side to side, just if I lift and drop it there's some play up and down. Shop is offering free service but cost of parts. If it's bearings and they're lifetime warranty, I shouldn't pay anything? Seems odd though for a part that will naturally wear. If they cost, then may as well do them myself as looks easy to do.
rhysw - how did you get on? I see in the guide they say to take care on those titanium bolts!
Posted : 21/04/2012 11:01 am
 DT78
They do offer life replacements, when I spoke to jungle about my mark1 they replaced the knackered ones for free. I did have to pay for an axle as that wasn't covered and your supposed to knock them out and regrease every 6 months, I hadn't and it had got scored. Worth noting it's probably unlikely all of your bearings need replacing unless you really mistreat it!
If my LBS or I had done the bearing replacement I would have had to send them back to jungle to prove they were knackered for a refund.
This was 2 years ago mind.
Posted : 21/04/2012 12:10 pm
I replaced the bearings on mine because of play and then realised it was the bushing on the rear shock!
Might be an idea to check that first?
Posted : 21/04/2012 12:37 pm
Been suggested but from what I can see the rear shock seems solid.
Not sure I like the idea of having to send the bearings off to get a replacement. Could be without the bike for weeks. Maybe that's why they sell the bearings. Could always buy them, fix up and them sell the replacements (or keep for later).
Posted : 22/04/2012 6:33 pm
I've just been through the process really quick an easy.
Knocked all my old bearings out using the proper sc tool. Posted them 1st class recorded on Monday with a photocopy of original purchase receipt and a cover note where I wanted the replacement delivering.
New bearings arrived in the post 2 days later. Top work by jungle!
Posted : 23/04/2012 12:06 am
