Saris Bones Rack - ...
[Closed] Saris Bones Rack - BMW 5 Touring ?
[#9760969]
Addition of a large black furry labrador means the bike had lost its boot space in the back of my 5 series touring. Use it for a lot of distance miles so don't want the roof rack on all the time but thinking a boot mounted carrier like Saris Bones would give me flexibility for short local bike runs.
Does anyone have experience of using the Saris 1 or saris bones II with a 5 series touring please?
Thanks !
Posted : 09/01/2018 1:25 pm
I've a 3 series touring and the saris 2 doesn't work,rear window at wrong angle for the feet too seat correctly,I've a roof rack/bike much easier ime.
Posted : 09/01/2018 2:09 pm
I lasted one instance of strapping one of those buggers on for "short local bike runs" before ditching it and getting a roof rack.
If you like your bike you'll spend 20 mins convincing yourself a boot strapped rack is set up right and nothing is rubbing, versus 30 seconds putting a bike in a decent roof carrier.
If your worry about about mileage with the roof rack on is fuel consumption based I'd say it only makes a noticeable difference when the bike is actually on. If it is wind-noise related, I find I only have every heard it with square roof bars.
Posted : 09/01/2018 2:21 pm
Will the Saris play nice with your frame?
Posted : 09/01/2018 3:22 pm
You wont be able to use the opening rear glass on the tailgate!
Get a towbar.
Posted : 09/01/2018 3:30 pm
I just used one of these short term between getting a tow bar fitted to a new car. They are impressively stable, so no worries with safety. They're fiddly, though, and the one I was using would scratch fk out of the motor long term [although was good with the bikes, good mounts]. Wouldn't say it was a good option if you care about the appearance of your car, but would be fine otherwise if you didn't want to spring for a tow bar.
Posted : 09/01/2018 3:38 pm
thanks all - sounds like a no for the boot - may look at getting some better roof bars that are easier to put on / off and more 'whispery'......
Posted : 10/01/2018 7:54 pm
I had a 5 Tourer and it had 3 Thule 591s on Wingbars for every one of the 80k miles I did in it over 4 years. Never took them off apart from an annual grease and lube. Never really noticed the noise and fuel economy was ok (though I didn’t have a non bar comparison)
Posted : 10/01/2018 8:16 pm
I had one that I used on my last cat but straps scratch the paintwork and I never really trusted it either, I would go roof mounted and take the rack off when not using it.
Posted : 10/01/2018 9:03 pm
Or invest in a towbar system.
as I suspect you won't remove all the bits and then pay the same money at the pump for a less accessible system.
[url= https://auxtail.com/about-cycle-carriers/ ]bike racks for cars[/url]
Posted : 11/01/2018 11:54 am
