are they please.
big boy's views only..
i had a blur 4x so cant comment in general, though i could flex the back end a fair bit with my twelve and a half stone, only when being a bit daft though.
17 stone plus here
and mine is GREAT...love it
My mate has bust two rocker links in 18 months, and is on his second full set of bearings. He's a strong chap, but not big or that mad on it.
Am 88kg. I love my Blur LT, really great XC bike and have had it down all kinds of madness in the Alps. I do tend to go through bearings and shock bushings fairly regularly though, I know they are supposed to wear out but they aint cheap and it happens fast enough to be a bit of a pain.
Is the only full suss I've had for any length of time so hard to compare. On my 3rd set in 2yrs, is that good or bad?
Don't notice any flex in back end.
depends how much you use them, but around here the shock mounts (top hats) seem to wear stupidly fast. (peak district) - ok they are getting used long and hard week-in week out, but the riders are 11 and 12.5 stone apeice. one is the alloy version, the other is carbon.
they seem to need new top hats every month!!!
No problems on mine (ridden pretty much every week & been abroad with it) - having said that it is in for a big service so my LBS might find something expensive..
how stiff in comparison to a heckler is a blur..
Mates rocker link went kapow in the Alps, he had to borrow another bike the rest of the week!
just been on mtbr reading up on em..........
dont think it is a good idea.
MisterT: Ditch the top-hats and get some decent shock mounts from BETD or TFTuned!
Ton have you considered Konas in you quest to personally keep the cycle industry afloat in these austere times? i an not as lofty as you but tip the scales at a cuddly 93 kg, have found the Coiler amply(?) takes all i can throw at it.
im 95kg an mine is sweet as a nut !! but nuts aint sweet ??
I think it's down to luck with the individual bike. I had my Blur for five years, and although at the time I varied between 85 and 100 kg I never had a single problem - indeed I never changed a bearing, and didn't need to even when I sold it. As long as the rear triangle is completely square to the frame you'll be fine. If it's slightly out I don't think it matters what you weigh, you'll be changing bushes.
[q]Is the only full suss I've had for any length of time so hard to compare. On my 3rd set in 2yrs, is that good or bad?[/q]
Well we do a lot of riding in the same conditions and my 4 year old Yeti 575 is still on the original bearings! The bushings could do with changing as there is slight play but bearings are fine.
MM
Should add I am 90kg odd too
Get another Heckler Tony..
You know you want too...
Ton - YGM 😉
