Salsa Regulator sea...
[Closed] Salsa Regulator seatpost
[#6145461]
Using one with a cromo railed Brooks Pro and experiencing some slippage aft. Tightening it up as much as I dare and it still moves back over time. Anyone experiencing similar?
Posted : 26/04/2014 8:47 pm
 gee
I had some issues with mine to start with. I eventually cured it with some precise greasing of particular parts...
- Grease the side bolt threads that adjusts fore/aft and tighten very tight, re-tighten after riding for a few miles.
- Don't grease the black inserts that rotate up and down or they will slip.
- Grease the bolt threads on the 5mm bolt that adjusts up and down tilt.
Posted : 26/04/2014 9:25 pm
 gee
I should probably add that I did the bolts up extremely tightly, almost crank bolt tight.
