Saint Rear mech adv...
[Closed] Saint Rear mech advice
[#3892630]
Before I press the order buttom can someone please confirm I've done my sums right.
Looking to run a 22/36 front and 11/34 back giving me a total difference of 37. I'm assuming I need to go for the RD-M810 GS
longer caged version, rather than the short cage version?
Thanks
Posted : 20/04/2012 1:49 pm
i run the short cage 1x9 with a 36t front and 11-34 cassette if that helps
Posted : 20/04/2012 1:52 pm
I run a 2x9 with 36t and 11-34 and run a Short GS.
Posted : 20/04/2012 1:59 pm
gsuperstar...
is yours a 22/36 combo upfront? Assume there were no issues setting it up?
I'm ideally looking for a shortcage, so if I can get away with it then great.
Posted : 20/04/2012 2:04 pm
Short cage details =
maximal pinion size: 28/34 teeth
· total capacity*²: 17/23 teeth
Whatever this means!
Posted : 20/04/2012 2:05 pm
Buy the GS, the SS is for single ring use.
Posted : 20/04/2012 2:08 pm
Just so we're clear, in Shimano's terminology there's no long cage (SGS) Saint, just a short (S) and a medium (GS).
I run the medium (GS) with 22/36 double up front and an 11/32 rear, and it works very well. I believe Shimano recommend the short (S) for single chainring setups only.
Posted : 20/04/2012 2:10 pm
I have run my short cage with a 24/36 up front combined with 11-32 out back. I didn't die 😉
Posted : 20/04/2012 2:29 pm
PS: The new 2013 Saint is 1x10 only, ie. single chainring and short(S) RD only, so pick up a 2x9 speed GS while you still can...
Posted : 20/04/2012 2:30 pm
Now you've got me wondering, so I looked up the Shimano tech docs for the specs. They say the short(S) model can handle a max tooth difference of 23T, while the medium(GS) can handle 37T.
Fuzzhead, your 24/36 x 11/32 comes out as 33T difference. The OPs 22/36 x 11/34 comes out as 37T difference. According to Shimano both are clearly a case for the medium(GS) cage, and while I'm not surprised you didn't die, I [i]am[/i] surprised your RD didn't - or are Shimano's guidelines way off the mark in this case?!?
Posted : 20/04/2012 2:49 pm
way off IME, I guess Shimano have built in enough fat to avoid warranty claims. Used my 36t x 11-34 combo this morning, no deaths were incurred 😉
Posted : 23/04/2012 12:15 pm
