Hi I took my new Glory Frame to Rutland Cycles today for them to build it up for me. I asked them to also bleed my Saint M810 brakes and while setting it up tonight the left hand lever reach adjustor will not turn, does anybody know if this is something easy to fix or why it is stuck and would people suggest that I ring them tomorrow to tell them about it.
Thanks
I had this on my xt's..
If there the same the little adjuster you turn should have a little tab inside it..
Get a little screw driver and lift the tab up, the adjuster should then slide straight off.
I gave my lever a squirt of wd40 and then used a pair of pliers to turn the shaft the adjuster slides onto.
If that doesn't make any sense let me know and I'll put some pics up in the morning.
Edit..looking at pics they don't appear to be the same.. not sure if the adjustment knob comes of on the saints.
