Saint Hub Centre-lo...
[Closed] Saint Hub Centre-lock Rotor Tool?
[#4672564]
Fitting the centre-lock rotors requires a cassette tool, which I have. However, it requires a deeper cut-out on the tool than the tool that I have has so that the tool can slide over the axle stub far enough to reach the lockring.
This is a Saint rear hub with Maxle setup.
Does anyone know which tools are compatible?
Whenever I've seen the Saint branded ones about they've always been very expensive, so I'd like to just buy a cheapo one that will do the job, but it's hard to find out whether they will do the job or not!
Thanks!
Posted : 21/12/2012 1:39 pm
Could you not get away with drilling the center of your current tool a slightly larger diameter than the axle stub, so you could get the extra depth?
Posted : 22/12/2012 4:06 pm
