Hello, I am currently mounting this shock:
https://www.sram.com/rockshox/products/super-deluxe-rct
I have recently received this gift:
https://www.sram.com/rockshox/products/super-deluxe-coil-rct
I would like to know how to adjust the same SAG in the dock.
Thanks! :).
Change the spring/adjust the preload by twisting the nut above the spring
Yep
Perfect!.
The bounce (of the Coil) has the same clicks that of the shock that I have mounted?.
tomhoward - MemberChange the spring/adjust the preload by twisting the nut above the spring
if you have to add preload you've got the wrong spring
So, the preload has to be adjusted or not?.
They're both kind of right - but then [url= https://sram-cdn-pull-zone-gsdesign.netdna-ssl.com/cdn/farfuture/rsQ25yFzbasI1zPphs90OHk3lghiEov1hV_6s3l0z90/mtime:1510696886/sites/default/files/techdocs/95.4118.001.000_user_manual_rear_suspension_rev_a.pdf ]you'd think the manufacturer had a manual that explained it all wouldn't you ?[/url]
All adding preload does is adjust ride hight and make small bump worse. The shock will still perform the same after it gets past the preload force. A small amount just to hold the spring in place is what you want. If you are using 1 or more turns of the adjuster then your spring weight is too light.
