Rusty hope rotors
[Closed] Rusty hope rotors
[#1163854]
I have some new hope hoops with the 3 bolt rotors but have noticed they are going quite rusty.Has anyone else experienced this?
Posted : 29/12/2009 11:30 am
Rotors are steel, ie they'll rust. Wire wool will take the rust off the arms - riding your bike will take the rust of the braking surface.
Posted : 29/12/2009 11:32 am
I think Hope rotors are made from Stainless Steel, the 'rust' you find may be the residue from sintered pads rusting on the rotors.
Posted : 29/12/2009 11:43 am
Just noticed my spokes are going RUSTY at the crossover points.GREAT!!Only 6 months old!!!!
Posted : 30/12/2009 12:07 pm
Your SPOKES are going rusty...???
Don't want to sound snobby, but if it is indeed rust then they can't be stainless. More 'budget-oriented' bikes have galvanised spokes which do indeed corrode.
As for the rotor: is it on the 'surface' of the rotor, or inside the machined-out bits? All the Hope rotors I've had go rusty there, but it doesn't affect anything.
Posted : 30/12/2009 12:11 pm
Wash your bike its probably mud, or you've been conned. Didnt buy them from Halfrauds did you ?
Posted : 30/12/2009 12:14 pm
stainless steel can still rust if not looked after. it just stains less.
Posted : 30/12/2009 1:02 pm
Indeed it can, but I've never seen SS spokes rust, even when I've scratched them, bent them, snowflaked them and generally not cleaned them.
Posted : 30/12/2009 1:06 pm
me neither, i meant the rotors tbh
Posted : 30/12/2009 1:07 pm
Bollocks
Stainless does not "rust" as you think of regular steel rusting with a red oxide on the surface that flakes off. If you see red rust it is probably due to some iron particles that have contaminated the surface of the stainless steel and it is these iron particles that are rusting. Look at the source of the rusting and see if you can remove it from the surface.
Posted : 30/12/2009 1:13 pm
