Rust on a steel fra...
[Closed] Rust on a steel frame
[#5060422]
Looking at buying a S/H frame, one of the frame's I am looking at has had some minor cable rub on the head tube which has turned a rusty colour, this doesn't rub off with a cloth. Is this something to worry about?
Posted : 12/04/2013 3:51 pm
no, unless there's metal flaking off.
if you're worried use a bit of chrome cleaner to clean it off and then nail varnish.
Posted : 12/04/2013 3:53 pm
As above, a bit of surface rust adds character. It's only worth worrying about if the frame is decades-old.
Spray loads of WD40 down the seat tube regularly, and leave it upside down to drain every now and again.
Posted : 12/04/2013 4:04 pm
You will be long in the grave before rust is a contributing factor to the failure of a frame.*
*This may be exaggerated, but the principle is correct.
Posted : 12/04/2013 4:07 pm
so rust that has accumulated externally on a frame over 6 months is not worth worrying about?
Posted : 12/04/2013 4:17 pm
I wouldn't worry about it, put it that way. 60 seconds with a wire brush will no doubt reveal good steel below the surface rust. As above, it's only worth worrying about if it's been left for years.
Posted : 12/04/2013 4:19 pm
plyphon - Member
a man from Genesis told me this - he also told me their frames have lifetime replacement warranty in the case of failure by rust.
Posted : 12/04/2013 4:21 pm
My Gary Fisher, illustrating that rust can kill a frame. I never did establish why he bothered powdercoating it having uncovered that but that's not the point...
[URL= http://i239.photobucket.com/albums/ff167/LukeBurstow/IMG_0640.jp g" target="_blank">http://i239.photobucket.com/albums/ff167/LukeBurstow/IMG_0640.jp g"/> [/IMG][/URL]
Posted : 12/04/2013 4:24 pm
wwaswas - does seem strange powdercoating a frame with holes, guess they occurred after blasting?
Posted : 12/04/2013 4:37 pm
no, I'd pointed out there was what looked like rust damage on the tube before he started and that was the main reason to get it blasted - to find the extent of the damage. I never though to say 'look, if it's scrap just stop at the blasting stage'
Posted : 12/04/2013 4:38 pm
you'd have thought he would have asked!
Posted : 12/04/2013 4:58 pm
wwaswas - can I mail you a pic for your thoughts?
wwaswas - Member
*checks Kinesis frame* 😉
Posted : 12/04/2013 5:01 pm
Blasting...!!!
Should never heavily blast a good quality frame as tubes are so thin. A very light blast just to key the surface for new paint, but should never strip the paint by blasting it.
Steel rusts, not a lot you can do but cover it back up. My SIR.9 has a few bubbles where the top tube gusset flexes. Doesn't bother me.
Posted : 12/04/2013 5:13 pm
Takisawa I was using the term loosely - he knew what he was doing in the blasting cabinet.
Kevster of course email in profile.
Kryton - I think the previous owner stored salt water in the seat tube of that GF 🙁
Posted : 12/04/2013 5:52 pm
