I do too but if I actually want to stop or slow down properly I'll apply the front. Dragging the rear brake is crap technique/habit I'm afraid, quite often with me it's not even having any slowing effect at all, something I'm trying to stop myself doing.I noticed that I drag/trail the rear brake alot
The road bike is set Euro stylee as I purchased it in France. Doesn't make any difference to me. I've just replaced my rear brake cable. The first on that bike since new, some 12 yrs ago. The cable was rusty.
MTB is set to Englandiashire and has DCLs fitted.
A spanner girl told me UK brakes are set as they are for right hand turn signal. Rear brake with left hand. Vice a versa for EuroShire.
I've got a Ti road build coming up later this year. I'm undecided which way round to set the brakes.
I say leave them euro style and don't tell anyone. Then if someone asks if they "can have a go" you then have god like Control of whether they go otb 😀 depends how much you like them. Haha mwuhahahaa 😈
Last time I was over there the helpful guy in the rental place heard my accent and swapped the brakes over without asking. That was pretty scary
I had the same in Whistler. I had to take the bloody thing back after my first run.
In uk when turning right across traffic waving right arm around in the air you brake with your left hand. The bike is easier to control with one hand while braking the rear wheel than it would be if braking the front.
Road bike, Singlespeed & Mountain Bike rear brake on the left
Jump Bike & fixie rear brake on the right
Never had a problem remembering what is where
I'm a bit confused here *prepares for flaming* I commute to work be it not far but I use a dual carriageway and obviously I signal my right turns going to work and coming home those rights becomes left signals. I don't switch my levers over before leaving work and I've not gone otb yet. So should I not left signal in case I die? And to add some background I do this route 5 times per week in all weathers and have done for 8 years. Should I stop playing the odds now? 😕
On a single carriage way you'd not normally signal and turn no need to slow for on coming traffic or stop in middle of the road. The whole left and right brake thing probably goes back before dual carriageways. Have a go at stoping a bike with one hand whilst turning see which one is easiest to control.
My point is that I signal both ways regardless of ease. If I got knocked off my bike because of brake setup and lack of signals then I'd accept I was at fault same as in the car. Also I use single carriageway too. Maybe I just slow down enough to control it before I signal who knows. *flame suit on*
I do too but if I actually want to stop or slow down properly I'll apply the front.Dragging the rear brake is crap technique/habit I'm afraid, quite often with me it's not even having any slowing effect at all, something I'm trying to stop myself doing.
I do this too - definitely poor technique! I think I do it as it manipulate the rear suspension into a more stable feeling position on my antiquated filing cabinet 😉
I'm doing it less these days as I've started getting my body weight more forward on the bike downhill. This has come with increased confidence, and has led to more confidence in the front end.
fathomer - Member
Hora, have a here about half way down the page for a how to:http://singletrackworld.com/forum/topic/psa-xt-m785-brakes/page/6
Just spotted this- ta very much 🙂
They've landed- I only ordered them Tuesday from Germany 😯 so will give them a quick spin tonight euro-style
I bloused out.. swapped but jesus the hoses are LONG
