Running tyres below...
[Closed] Running tyres below their recommended PSI
 PJay
[#11237978]
I've been off the bike since October (heart issues) and am tentatively starting out again. I ride (pootle) gravel on my Swift and have picked up a pair of [url= https://www.vittoria.com/eu/terreno-cross-country.html ]Terreno XC tyres[/url] in 2.1" size just to try something new (they replace 2" Kenda's).
They're rated at 30-50 psi (I used to run the Kendas at about 35psi) but even at 30psi they feel rock hard. I think that part of the issue is that they're huge, much bigger than the nominal .1" increase would suggest; I'm putting it down to generous sizing and much taller sidewalls (rather than them being mislabelled 2.25s).
So is there a problem running them lower? I assume that PSI ranges are there for a reason. I'd probably only drop them 5psi or so to start.
They're set up tubeless which, from what I gather, usually means that they can be run a bit lower than if tubed.
Posted : 08/06/2020 1:07 pm
Don’t think I’ve ever used a tyre within the stated PSi
Posted : 08/06/2020 1:09 pm
You can safely ignore recommended PSI ratings, especially if running tubeless.
Posted : 08/06/2020 1:11 pm
You can safely ignore the lower PSI rating, would not ignore the upper unless it's just to get the tyre seated 🙂
Posted : 08/06/2020 1:17 pm
You know, I don't think I've ever checked what pressure a manufacturer has recommended. Since I went tubeless, I use about 20-ish  front and 25-ish rear, and adjust a bit up or down from there.
Posted : 08/06/2020 1:20 pm
I run 2.3 tires at 15 psi.
Posted : 08/06/2020 1:37 pm
Jumbo Jim's at 5 psi - even had to get a digital guage to get the pressure right. They ride so much better on the snow when they're that low.
Posted : 08/06/2020 3:24 pm
I run my 29+ at about 12 psi and on my fat bike, I've run them as low as 1-2 psi on soft snow, because any higher and you're pushing.
Posted : 08/06/2020 3:36 pm
 nuke
There's a psi range for tyres!?! Genuinely can't remember ever looking but i i guess I'd always be going lower anyway and assume that at average weight, itd be in or close to range
Posted : 08/06/2020 3:41 pm
 PJay
Cheers All, I'll have a play.
Posted : 08/06/2020 5:22 pm
