Running 650b forks ...
[Closed] Running 650b forks on a 26" rim
 hora
[#6278356]
Secondhand there seems to be more choice now for decent 650b forks whereas 26" forks are maybe becoming long in the tooth? (I don't want a wheelsize debate- both are awesome).
Apart from the extra axle to crown height whats the difference?
Ultimately I'd be swapping my 26" rim for a 650b one but for now are there any downsides? Axle to crown is 554mm which is almost identical to 26" Marzocchi forks that I also own.
I don't see a prob? Maybe abit more 'space' between the brace/tyre.
Posted : 18/06/2014 9:20 am
YOU WILL DIE!!!*
*(You'll be fine)...
Posted : 18/06/2014 9:32 am
I've noticed a glut of second hand 26 and 29 er forks recently but only a few 650B cropping up, new is another matter, but still seems plenty of choice second hand.
Apart from the possible (depending on make/model) mild increase in A2C height there's nothing much worry about. I'm sure a few 650B forks are using a different offset now so could be worth paying attention to that but they'll still work.
Posted : 18/06/2014 9:48 am
 hora
20mm difference so about 1degree slacker?
150 Mazz 26" are c535mm high, 160 Fox 34's 554mm so no biggy.
Posted : 18/06/2014 9:57 am
650B Pikes with a 26" rim/tyre:
tbh, with chunky tyres, you can't really spot the extra length in the fork lowers!
Posted : 18/06/2014 11:15 am
Will your downtube have clearance for front wheel when bottoming out forks?
Posted : 18/06/2014 11:53 am
 hora
Shirley you'd have more clearance?
The bike does look alot 'taller' though- is that a fair comment?
Posted : 18/06/2014 11:56 am
650b forks are (to generalise) slightly longer, but have more offset. So the geometry theory is that you'll have a slacker head angle but the offset should speed up the handling and "cancel it out". The end result is a very slightly longer wheelbase. At the end of the day, and talking to people who have done it, you can't even tell the difference.
Posted : 18/06/2014 12:11 pm
 Del
if it's longer in the leg and and shorter in the torso you probably want a large.
of course it looks taller you've put a longer fork on it you spaz!
Posted : 18/06/2014 12:21 pm
quality comment
Posted : 18/06/2014 12:26 pm
I think that's just that bike. I'm also running 650b forks and 26" wheels:
i thought you "mazz" were the best forks ever, always state that on pike threads. Fox 34 though - LOL
#toopoorforpikes
Posted : 18/06/2014 12:27 pm
Rob & Hora, I think you need to get a room, or a least go for a mince round the Peak together 😀
Posted : 18/06/2014 12:32 pm
I think the angle that i took that^^^ photo from of my Zesty makes it look shorter/taller, than it actually is. In the "flesh" so to speak, i don't think you'd even notice it had a 650B fork on it etc
Posted : 18/06/2014 12:33 pm
I was initially slightly concerned the fork lower "hoop" that wraps over the top of the tyre might look silly if it had a load of fresh air under it, but certainly with "Big" 26" tyres like those HansDampfs it looks fairly normal. With a more XC flavour small volume tyre it might look like a bigger gap, although that means there would be plenty of space for a mud deflector etc! 😉
I also thought that if the front feels too tall, then i'd just fit a 1 deg angle set which would lower the front back to where it came from
Posted : 18/06/2014 12:35 pm
It just looks like Fox 36s always look, you wouldn't even question it.
Posted : 18/06/2014 12:39 pm
Im sure when we were looking for Abigale some new forks that the Slants were marketed as 26"/650b compatable. Think it has a bit more clearance
Posted : 18/06/2014 12:44 pm
 hora
#toopoorforpikes
I'm not a RS fan. I'm Mazz and Fox regardless.
Posted : 18/06/2014 12:46 pm
