"Rugged" ...
[Closed] "Rugged" 29er
[#5258016]
Ok - I was going to buy a Solaris as my step towards the darkside - for XC stylee duties
But after a few threads here , maybe I should consider a FS ...
Ok , I weigh 130 kgs , 6ft 3 inches - so I think a spearfish is going to be like riding spagetti ...
Is there any heavy duty 29er that I should consider - Transition Bandit comes to mind.
Looking at 120mm f/R
One proviso - despite the fact that I may be a chubster, I don't want it to weigh much more than 32lbs.
And yes , I can shed some ballast and am trying to do so ... 😆
Posted : 18/06/2013 3:50 pm
 IA
If you're looking at the spearfish, what about the horsethief?
(6'4" and have an XL one, it's ace)
Posted : 18/06/2013 3:54 pm
Loving my new Stumpjumper FSR 29er here. Bought one of these £800 frames:
[url= http://www.bikescene.co.uk/Specialized-Stumpjumper-FSR-Comp-29-Frame-5988-0-0.html ]http://www.bikescene.co.uk/Specialized-Stumpjumper-FSR-Comp-29-Frame-5988-0-0.html[/url]
Built it up with a [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=94595 ]130mm Rev 29er[/url], Merlin'd an SLX groupset. Frame weight was about 7lbs for a monster big size.
The huge wheels almost mask the fact it's an XXL frame! Definitely not spaghetti, 142x12 axle on the back end probably helps.
Posted : 18/06/2013 3:55 pm
Orange bikes tend to be pretty tough, so how about the Gyro. The one I tested was a large and was spot on 32 lb. Seemed pretty rugged to me.
Posted : 18/06/2013 4:04 pm
I used to have a patriot - though admitedly a 2006 one. Dunno - never loved it, 18 inch frame was sort of small.
And somehing in my head tells me that the frames are way over priced - and I got piss all for mine on eBay. However someone did really well !! I guess I have a grudge !
Posted : 18/06/2013 4:07 pm
Budget? I would class my Nicolai AC 29er as pretty rugged, and it weighs just under 32lbs running a heavy Hammerschmidt crank. I would guess at sub 31lbs running 1x10 or 2x10. It’s 140mm travel though, not 120mm.
Posted : 18/06/2013 4:11 pm
horsethief
Posted : 18/06/2013 4:15 pm
Salsa Horsethief. Not sure whether they can still be had cheap, but I got mine for £800 with a 2013 Fox CTD.
[img] :large[/img]
Posted : 18/06/2013 4:16 pm
Norco Shonobi ? Ok it's got 140 up front but so what.
Posted : 18/06/2013 4:28 pm
Turner Sultan?
Posted : 18/06/2013 5:51 pm
Turner Sultan like wot he said.
[URL= http://i74.photobucket.com/albums/i253/fartootall/Bikes/Turner%20Sultan/DSCN1202.jp g" target="_blank">http://i74.photobucket.com/albums/i253/fartootall/Bikes/Turner%20Sultan/DSCN1202.jp g"/> [/IMG][/URL]
My Sasquatch (23" frame) weighs in at 30lbs all up and it wasn't built for a weenie.
Posted : 18/06/2013 7:08 pm
llama.
How are you getting on with that fork?
Posted : 18/06/2013 7:16 pm
The Horsefeeth seems quite an expensive option for all the usual sources - will scan it all tonight
So no transition bandit fans?
Posted : 18/06/2013 7:33 pm
love mine... it's a '12 so 140/130.
if you are a big fella then a 34 fork would make sense on whatever you get.
llama how is that fork...
Posted : 18/06/2013 8:19 pm
If you're looking for a FS XC bike that works well on rough trails but is also not "Too Much" on smoother stuff how about the Pyga OneTen29
Mine weighs about 28-29lbs and the frame is very stiff and solidly built
Front is 120-130mm
My other bike is a Solaris
Posted : 18/06/2013 8:38 pm
llama.
I'd maybe swap them for fox 34s, but not 32s or revs, which are both less stiff and less progressive.
With a big IMO.
Took a good few rides to bed in and v sensitive to pressure and rebound, so setup is a bit lengthy.
Posted : 18/06/2013 11:28 pm
Trek (Gary Fisher) Rumblefish. I'm about 200lbs and find that this is a very stiff frame. Brilliant downhill and, once the shock was set up for my weight(Mojo), a great climber as well. Weighs 32lbs and has 120mm travel as requested. 🙂
Posted : 19/06/2013 7:54 am
I have been having this exact same self-discussion and have even considered dropping to a 26" for this type of bike. For example a Cannondale Jekyll 3 can be had for £1800 with £1300 off RRP, but you simply can't get them sort of discounts on a burly 29er.
What i really want is a Commencal AM29.
Posted : 19/06/2013 8:11 am
I like my Trigger 1 but I think the rear shock will be a bit soft for you. 110kg rider equals 600psi which is the max you can put in.
Posted : 19/06/2013 8:46 am
Hi,
Just to add another one into the mix, I am 6' 4" and now a svelt 110kgs (was 125 last year), and as the legendary "Ton", another bigger gent, used to do, I ride a Ventana El Capitan. Stiff as ****, plush, lovely.
Kev
Posted : 19/06/2013 9:09 am
26 FS seems to offer better value ...I would be in an "i want it now " mode , not after test riding 100s ( I don't have time)
Maybe it's back to the solaris plan ... which isn't a bad one anyway ..
Posted : 19/06/2013 7:55 pm
