Looking for some new rubber bands that hold my lights on as cant find them !!!
Anyone got a link where i can get some please 😀
look for O'rings at B&Q or Ebay?
[url= http://www.candb-seen.co.uk/accessories/cables-o-rings-and-helmet.html ]here....[/url]
Any solutions for a better fixing?
Bought loads from c&b ( great service and quick delivery) but fed up of losing them...
Glue the one end on?
Thin cable tie? Works for me, although it could get a bit wasteful if I didn't basically fit them for the winter.
I can post you a couple of new ones (the better ones in the photo above) if you PP me a couple of quid for postage.
http://www.chainreactioncycles.com/hope-universal-handlebar-mount/rp-prod23533
Check your light out, the mount on it should unbolt - and you can then bolt this on.
Might need a longer or shorter bolt depending...
HTH
Si
binno - Member
POSTED 3 HOURS AGO # REPORT-POST
Cheers Binno,will do when I get in from work ,pm me ur PP details please
Obviously, phoning an O-ring supplier & [i]speaking nicely[/i] to the nice lady & asking for [i]samples for a project[/i] is not to be condoned.
Improvise with a piece of old inner tube?
I made a mount using my old vistalite bar mount - screws into base of light using screw that comes with light - works perfectly if you can find a vistalite hanging around somewhere
Here's a quote from a friend of mine... I haven't investigated further:
It appears that multisize Silicone Cock Rings are just perfect just like big O rings really and at a fiver for three and different size diameter means I've got new mounting brackets and that fit differing size points t a fraction of the cost!
Just putting that out there, as it were.
btw those O rings are great at keeping the top hat washer in place for GXP BBs
