RSP Plummet Plummet...
[Closed] RSP Plummet Plummeted... Maintenance etc???
[#9382786]
My RSP Plummet has come undone from itself, that is the silver bit in the bottom of the post has come unscrewed from the outer, as in this image:
Only had it just over a month, fitted to commute bike so 330+ miles, 40+ rides.
Looks like a bit of water has got in. Guessing I should just clean and re-grease and screw it back together?
Still can't find any service manuals or anything, might try emailing Raleigh.
Posted : 14/06/2017 7:05 pm
Yeah, just screw it back in. It adjusts the spring that bit. As far as servicing goes, just take it apart, grease it up and reassemble. It's a pretty simple design.
Posted : 14/06/2017 9:24 pm
As determined by how far I do it up into the post? Goes in quite a way.
Definitely feels like it will rattle loose again. Will probably put some medium thread lock on.
Assuming I should screw the silver shaft all the way into the uppy-downy-post bit (not shown in pic) before screwing that lumpy threaded end bit in.
Posted : 14/06/2017 11:29 pm
Actually on second thoughts, that's different to the one we had, so I'm probably talking shite.
Posted : 14/06/2017 11:42 pm
