Hi folks , did the great glen way at the weekend and had a seatpost bag under the seat for 2 days. Now due to this the tension seems to have came out the cable in my RSP plummet dropper . Its the newer 125mm one and I seem tohave mislaid the instructions. There seems to be little online in regards to instructions. Any help is appreciated.
I've got one but haven't used it for a while. Not sure what your problem might be without more information. What have you tried so far? The trigger is a bit wafty and very good at mangling the cable with the grub screw which holds the cable in place leading to the cable threads breaking one by one over time. Another problem with them in the seatpost where the small cylinder which holds the cable end came loose and was only half held in by the thingamajig so lost leverage power.
