Got a set of Tora 302's that are set to 80mm. Been trying to sell them but with no joy. If I can remove spacers and set them at 100mm I'll probably have more luck but I don't know if ...
1. They can be adjusted.
2. How to find the spacers and
3.How to remove them.
Everyone say's it's an easy job but having never had a set of forks apart before (other than swaping a damper cartridge in a set of Rebas), I don't want to "F UP" a good set of forks.
Help/advise would be appreciated.
Coil sprung so there shouldn't be spacers like an air sprung fork. Don't they have shorter springs & stanchions so achieve the shorter travel
Not always boardin bob. Toras can be adjusted for length in the usual way of removing spacers.
andy - manuals can be found on the rockshock site
Ah right. So the spacer pre-loads the spring to reduce travel?
Thanks guys.
