looking to replace my pikes for something lighter but cant find weights anywhere for coil sektors. 🙂
can't quite recall by how much but they are definitely lighter than Pikes, by maybe 300g..?
thanks reggie
1837g according to CRC
2108g for the coil uturn. Pretty hefty, Lyrik teritory.
that is pretty heavy yeah think my pikes are round 2200g, might have to settle with air sprung, my hard tail feels a bit unbalanced with the weight on the front end !
Lyrik coil u-turns are 2412g, so about half a pound heavier.
True Rickos but I think the Lyrik solo air comes slightly over 2100g.
Was going to suggest the 2011 Marzocchi 44 RC3 Ti at CRC but it looks like theyre sold out. 2010 version still in stock http://www.chainreactioncycles.com/Models.aspx?ModelID=42256
1927g which is good for a 140mm coil, just over £300.
pretty sure my RL u turns were nearly 4.5 lbs
I'm on the lookout for some forks and was eyeing up some coil Sektors - I guess to get the weight below 2Kg I should be looking at air forks, then?
Just weighed some 150 U-Turn Sektors - with added RRP mud-flap thing and an older 20mm Maxle fitted plus a brake adaptor they come in at 2240g. Steerer cut to around 195mm. So yes, Air Sektors I guess. Or Revelations.
