RS revs not winding...
[Closed] RS revs not winding out to full travel
[#2163985]
only get them to around 125mm, is the air pressures? have tried looking at them currently -ve & +ve both set at 125psi.
if i pull the lowers down then i can get them to 145mm but they suck back up to 125mm when left alone..?
any advice would be gteat please..
dual air model if it helps..?
Posted : 06/11/2010 8:11 pm
Let all air out of + and -. Squish forks up and down and let air out again. Pump up positive to normal pressure and see if you get full travel. Fox forks sometimes suffer hydraulic lock down, not sure about RS.
Posted : 06/11/2010 8:18 pm
cheers, will try that after walking the dog...
Posted : 06/11/2010 8:34 pm
I think boxelder might be on the right tracks - the Revs do seem to have a bit of a habit of it, and on this thread [b][url= http://www.singletrackworld.com/forum/topic/no-travel-and-compression-damping-in-my-revs ]here[/url][/b], I've recounted some advice that my LBS gave me (and thankfully, some more mechanically minded STW forum members seemed to agree with it!) that sorts this out. Hope it's of help.
Can't recall now, but I think they said it's best to do it in a workstand so's your front wheel's unweighted, allowing the fork to move up / down of its own accord - that's how I did it anyway and it kind of made sense.
Posted : 06/11/2010 8:36 pm
all good now cheers for the advice
Posted : 06/11/2010 10:18 pm
