Got some Rev Races for the missus' bike. They came with remote poploc, but her 31.8 handlebars bulge in precisely the wrong place to allow the remote lever to be mounted (without moving her brakes to somewhere sub-optimal).
Is there any way that you can swap to non-remote poploc?
Dave
ps I've got Rev Teams on my 575 with the non remote control, so if they are swappable between forks, that could be doable.
Yes, just unhook the spring from the motioon control cartridge. Peter Poddy has a guide somewhere
You can take the damper out, unhook the spring and replace the top cap with an non-remote one.
You can also swap your non-remote damper for her remote one in about 2mins. Although, if your team versions are 09/10 ones they will have the blackbox damper, so you'll be swapping for her standard one (this might require and oil level change too)...
You'll be needing this then! 🙂
[url= https://docs.google.com/fileview?id=0B1AoGIWBz4H1YWNhYWRkODYtNzRiNi00YTA1LTlmMjctNmQzOWQwMDdiZGFl&hl=en ]CLICKY[/url]
So long as neither of them are 'blackbox' then you should just be able to wheech the cartridge out of one and put it back in the other.
Remember to remove the cartridges VERY slowly to allow the oil to dribble back into the chamber, otherwise you'll need to measure and refill.
Alternatively unhook the spring as clubber suggests, and you can buy the lever for the top of the leg if you really want to neaten things up.
what are your plans for the poploc?
....which can be bought [url= http://www.tftunedshox.com/Catalogue/Shop-RockShox/RockShox/RockShox-Fork-Spare-Parts ]here[/url].
blimey, I think this might rate as the most useful thread I have ever read on STW 🙂 It seems that if you ask the right question, all manner of doors open up to you!
My forks are blackbox, and non-remote, so does that mean that they won't have the spring in there so I can't fit her remote to mine?
Dave
I was told (by the importers) that blackbox and non-blackbox forks couldn't swap cartridges.
If yours is non-remote then I doubt you could convert it. Looks like you'll need to un-hook the spring.
basically yes: if there's no return spring in there in the first place you won't get one in to pull 'against' a bar mouted lever.
OK Cheers guys.
re Pook:
I do some remote poploc rebas on another bike with no remote (smashed it in a crash), so could use it there... or i suppose I could sell it. TF Tuned list them at £65 !!
Dave
I don't see any reason why that might be the case assuming the leg/crown/thread size is the same (which I'm sure it will be).
The only likely difference is the length of the 'spring' that is plastic on the standard forks and titanium on the blackbox ones, meaning you'll need to adjust the oil height in the leg.
I might be wrong though, I don't have a blackbox MC compression damper to compare.
Ah. You've caught me there Glenh, it might not have been blackbox vs. motion control, it could have been powerbulge vs non-powerbulge lowers
Either way, I had a faulty damper in my new, blackbox, powerbulge rebas, and when I asked fisher if I could just put my old MC damper in there while they looked at the blackbox one, they said they weren't a straight swap.
