RS Reba 29er fork s...
[Closed] RS Reba 29er fork setup?
[#623031]
Does anyone know what air pressure PSI for the negative chamber on the 29er Rebas. I have 250 in the positive or preload bit. I'm around 16 half stone. I thought this would save me hours of messing if someone had an idea what was a good PSi to start with.
Posted : 11/06/2009 12:40 am
12 & 1/2 stone, using about 100psi in both positive and negative chambers. start with equal pressure in both, but 250 sounds high to me.
Posted : 11/06/2009 7:28 am
I run 135 psi in each and I'm 14st
as above start with equal pressure and add/remove neg according to taste.
Posted : 11/06/2009 8:10 am
I'm similar weight and run the same top and bottom. I used the max pressure that was in the instruction book, but I seem to remember that it was 150psi, not 250psi. That seems very very high to me. Can you damage the internals with that much pressure?
After a little fiddling I think I reduced the pressure in the bottom by about 15psi to get it really dialed in, but start with the same in both
Posted : 11/06/2009 8:20 am
 mije
if anything a little less in the positive chamber to make the fork a little less active. 10 stone -100, +80
Posted : 11/06/2009 11:05 am
it was 150 PSI the max pressure as stated above. I will stickthe same in them and go from there. thanks a lot.
Posted : 11/06/2009 6:52 pm
just serviced mine tonight and reduced the travel so now running 145- 140+
Posted : 11/06/2009 7:02 pm
Are they easy to service Stoner?
Posted : 11/06/2009 7:24 pm
Kind of.
DOwnload the manual, it's pretty good.
But it does miss out stuff about where the oil goes or how to service the damper circuit without taking the lowers off etc.
It all comes with practice.
Ive had rebas for nearly 3 years now and have had them open probably 5 or 6 times so am slowly getting the hang of them.
Posted : 11/06/2009 11:22 pm
