Hi
I have a 14 Pike RC with charger damper and a 18 Revelation RC with the moco damper.
Can I put the Pike damper in the Rev or easier to buy a new charger 2 kit ?
The moco damper is pants and spoiling the ride of my Chameleon
Ta
The charger 2 damper should fit and the revs can accept that damper so I think it should.
Its complicated as there's a ton of different 'A' Pikes, but I am guessing yours would be non-boost, in which case the damper won't swap into a more modern fork.
I thought you could upgrade A1 and A2 pike to charger 2
Might just get a charger 2 for the Rev then as sounds easier
You can upgrade all 35 forks to charger dampers, but you probably can't put the damper from the OPs pikes in his Revs.
Impossible. A Pike RC 14 will be none boost with a far more corse top cap threading. The Revelation has a very fine top cap thread, RS changed the Pike to this same thread but only on the A2 boost fork, the Lyrik B1 has always had the fine tread.
