RS Pike 454 advice ...
[Closed] RS Pike 454 advice please
[#1543114]
My Pikes have run untouched for a while, but little used & lubed the stanchions after each ride. All was well until I decided to check the pressures - top +ve pressure was fine but when I attached the pump to the lower -ve valve it pushed oil into the pump. A bit of further investigation showed quite a bit of opaque oil in the valve.
Simple questions - should this happen? If not, what's wrong? And are there any really, really basic simple-to-follow instructions on how to service them?
Thanks
Posted : 25/04/2010 5:02 pm
 nuke
[i]should this happen?[/i]
Yes.
If you don't want it to do it, turn the bike/fork upside-down before setting -ve air pressure
Posted : 25/04/2010 5:04 pm
logic told me that, but being a numpty I wasn't sure. Also, just found a couple of Youtube clips where oil doesn't come out.
Anyway, if all's OK I'll forget about it!
Posted : 25/04/2010 5:11 pm
You can get oil out of the positive chamber as well sometimes.
Posted : 25/04/2010 7:11 pm
wouldn't hurt to top up the oil in the air chambers at some point, should be fine for the time being though
Posted : 25/04/2010 7:28 pm
This is normal. Careful you don't get oil on your disc!
Posted : 25/04/2010 7:40 pm
