Does anyone know where to buy the correct damper unit for Rockshox Lyrik 115-160m U-turn. These are the AM forks and not the DH forks.
The damper unit im after has low and high sped compression and is to be fitted to a plain old Rebound set of lyriks to upgrade it.
cheers
scott
LoCo?
I bought dampers from [url= http://www.mountainbikes.net/mtbikes/produktlistek.cfm?ctry=1&za=1&lc=1&curcd=1&cid=110805051702&katid=1023&PNR=20931&gbnr=23 ]these people[/url] in Germany- took about a week to arrive.
Depending on what model and year of Lyrik you have you might need to upgrade the rebound damper as well, I can't remember but I think that there's no point to having the MiCo compression cartridge without the corresponding rebound damper- the lower spec rebound dampers don't flow oil quickly enough to allow the compression damper to work properly. Or something- google should throw up some talk about it. I just took it as gospel, and bought both.
HI vinny, how much did it all set you back?
Yes can supply MiCo damper setups, have a couple of MiCos left on the shelf so can do a silly deal on these, drop me a mail 😀
