Hi, looking to see if my old Revs air shaft 2018 (35mm) version will work on my 29er Lyrik 2016/17.
The full length is 247mm top to bottom. Pretty sure this came off a 150mm travel. No markings as guessed it’s OEM. Could someone advise me if this will work as a 160/170mm lyrik air shaft please? From the info I can find it should equate to a 170mm Lyrik but without any markings I’m not sure!
Should say I have a Luftkappe which I’ll swap over so just need to make sure it’s the right length shaft 🤣
[url= https://i.ibb.co/rFxmhCy/1-B17653-D-A5-D0-448-A-97-F6-0-F25-CADFA750.jp g" target="_blank">https://i.ibb.co/rFxmhCy/1-B17653-D-A5-D0-448-A-97-F6-0-F25-CADFA750.jp g"/> [/img][/url]
Thanks
I think Lyrik/Yari airshafts are 10mm longer than the Pike/Rev ones.
Thanks TG
