RP23/Propedal switc...
[Closed] RP23/Propedal switch, adjust on the move?
[#6394960]
So, I've become a traitor to the hardtail world and gone low end FS. The shock on this is an RP23 and the fox manual says "only adjust when you're not moving". My question is, is that a liability thing, or can you do any physical damage to the shock by adjusting when you're rolling.
Posted : 08/08/2014 12:39 pm
 nuke
Does it mean switching propedal on and off or adjusting propedal level (1 to 3 setting)? If its the former, on the fly is fine, if the latter, it could be fiddly to adjust whilst riding so probably better to stop.
Posted : 08/08/2014 12:41 pm
I always adjusted mine on the go, it blew up - After about 4 years hard use.
Posted : 08/08/2014 12:46 pm
My RP2 manual says "for adjustment in the fly" in one place, then a safety warning saying "don't adjust on the fly" elsewhere.
I do it and haven't died.
Posted : 08/08/2014 12:47 pm
I think they are mainly trying to avoid lawsuits from people crashing due to trying to adjust fiddly shocks on tricky trails rather than being worried about it breaking. Early dropper posts without remotes had the same warning for the same reason.
Posted : 08/08/2014 12:57 pm
Never had an issue adjusting the on / off lever on the go on mine, but as has been said, the propedal level knob (adaptive logic knob on the newer ones) would be pretty tricky to adjust on the fly.
Posted : 08/08/2014 12:59 pm
 gren
RP2 here and is fine switching on the move - not that it's used much.
Be careful not to kill yourself when bending down to reach it though!
Posted : 08/08/2014 1:51 pm
thanks, kinda confirmed what i thought.
Posted : 08/08/2014 2:41 pm
