RP23 DIY service - ...
[Closed] RP23 DIY service - possible?
 sv
[#967165]
Easy to do a seal service and rebuild or TFT treatment only? Any online how tos if it is possible - cheers.
Posted : 20/10/2009 7:34 am
[url= http://www.foxracingshox.com/fox_tech_center/owners_manuals/07/eng/rear_shocks/air_sleeve_maintenance.htm ]
Link to Air sleeve service info[/url]
Posted : 20/10/2009 7:36 am
 sv
Great thanks for that.
Posted : 20/10/2009 8:06 am
You won't be able to do the 300psi nitrogen in the shock body though.
Don't go away thinking you can unscrew everything willy-nilly.
Posted : 20/10/2009 8:19 am
SO - he did say in his OP "seal service" so I dont think he's going to take it further - esp with the service instructions on the fox website IMHO 🙂
Posted : 20/10/2009 9:40 am
Better safe than sorry eh? 🙄
Posted : 20/10/2009 9:42 am
Point taken SO 🙂
Posted : 20/10/2009 9:49 am
 sv
Whats the worst that could happen - 😆
Posted : 20/10/2009 9:57 am
Its just getting the sleeve back on again is the difficult bit - as long as you put it back in teh frane and use that for leverage its fine but dont do it in a dust garage and clean your bike off first etc - keep it clean and dont use dusty rags!
I presume you have some float fluid before you start ?
Posted : 20/10/2009 10:00 am
 sv
The seal kit includes a 'pillow' of the fluid - I think! Its for a mate and I have asked him what he thinks is wrong with the shock. He cant quite afford the £100 for TFTuned to do it for him, thought I might be able to help. Although in a selfish way it will help when I come to do my RP2! Always try things out on somebody elses equipment first 😉
Posted : 20/10/2009 12:23 pm
I did mine a few days ago and yes it does have 10ml or float fluid in the seal kit :). It may not sort your problem out but sometimes problems go away with a seal service from the feedback I have got from STW. If its got sueck down be careful but I doesn't sound like it suck down/stuck from what you have said 🙂
Posted : 20/10/2009 12:36 pm
There's a good guide here - http://forums.mtbr.com/showthread.php?t=401486
Re getting the air sleeve back on - make sure the pro-pedal is off & it shouldn't be too difficult
Posted : 20/10/2009 12:39 pm
I saved this video for the old Vanilla shock, but it's still pretty much the same, gives you a good idea what to expect.
Sorry for poor quality, but I lost the hi-res one 🙂
[URL= http://i142.photobucket.com/albums/r90/dezb99/Junk/th_air_vanilla_low.jp g" target="_blank">http://i142.photobucket.com/albums/r90/dezb99/Junk/th_air_vanilla_low.jp g"/> [/IMG][/URL]
Edit: Uplink's link is definitely worth checking out too.
Posted : 20/10/2009 12:40 pm
Dead easy to carry out the 'air can service'.
You'll need 2.5ml of float fluid - the thick blue oil. Some grease. Some panel wipe or brake cleaner.
Takes about 10-minutes. Did mine for the first time two weeks ago and the shock felt brilliant afterwards. I hadn'r realised how much it had deteriorated.
MBR did a guide in the March 2008 edition. I'm sure a youtube search would produce a video guide.
Posted : 20/10/2009 12:42 pm
There was an MBR workshop piece on seal service. Suggest you have a look.
Posted : 20/10/2009 12:48 pm
Foxy if you are struggling to compress the shock to screw the can back on, check the switch is in the open and not propedal/lockout position.
Posted : 20/10/2009 1:01 pm
 sv
Cheers all, under what circumstances would the Nitrogen need recharged?
Posted : 20/10/2009 1:14 pm
 K
Nitrogen would need recharging if the damping isn't working as it should, thus needing the damper to be serviced not just the air can.
Posted : 20/10/2009 1:25 pm
When the damping oil is changed.
It'll start making bubbling sounds or honking like a duck when the time is upon it.
 sv
Ok lets hear that loud pop then...
Thanks again.
Posted : 20/10/2009 1:35 pm
