Just picked up a second hand anthem, appears to be a lot of oil on the shaft of the shock. Wiped it away, bounced up and down, wet again. Assume the seal has gone? Is it time for a full service and who do you recommend? Is custom tuning worth it?
Why not service it your self?
I bought a seal kit from Mojo, and watched a Fox video on youtube.
It was quite easy and a very cheap way to do it. You just have to be careful not to scratch the parts.
Innes
Hmmm how much did it cost you to DIY?
The seal kit is £10 and I think Loco has them if not Mojo will. It is very simple just remember to let the air out first 😀
Might give it a go then. Does the rp2 need the same seal kit as.the float?
