Route planning webs...
[Closed] Route planning website for rides
[#7198213]
Hey dudes and dudettes.
I'm away next week and will have my bike with me, but to an area I don't know. Is there a website that you can search for cycle routes, on or off road, from a postcode?
Posted : 16/07/2015 1:32 pm
Not that I know of.
I was advised to use a strava heat map which works well, and you can use it even if your like me and not down with this strava malarky.
Comes up with a quick google
Posted : 16/07/2015 7:47 pm
Worth a gander
http://www.opencyclemap.org
Not really what your looking for, but lots of trails on it. But variable I'm told admittedly.
Posted : 16/07/2015 7:52 pm
http://www.gpsies.com/trackList.do
Posted : 16/07/2015 7:54 pm
Why don't you just Google in, 'Cycle routes around *insert location name*'
There's probably some club/individual that's got some routes on a web page.
Failing that, buy an OS map & go investigate, It's how you find out!
Posted : 16/07/2015 8:03 pm
http://m.cyclestreets.net/
Put in start postcode, put in end postcode and if you click to get the quietest route it'll usually pick up bridle ways and sustrans tracks too.
Posted : 16/07/2015 8:07 pm
ridewithgps and make your own routes 🙂
Posted : 16/07/2015 8:10 pm
[url= http://my.viewranger.com/route/search#!56.81766632979249|-5.104875450134273|14 ]Well, there's viewranger.[/url]
Or
[url= http://www.mtbtrails.info/Trail_main_page.aspx ]MTB Trails[/url]
Posted : 16/07/2015 9:37 pm
Also, I don't really use strava but when I've googled for routes, for instance at Inshriach and around Aviemore, strava has come up with some interesting results.
Posted : 16/07/2015 9:41 pm
Cheers for replies, Kunstler view ranger looks spot on.
Posted : 17/07/2015 12:47 am
Bikely's worth a try
Posted : 17/07/2015 7:29 am
If you do use strava you can make your own routes on a computer and it looks like from the latest update, have them displayed on your phone as you ride round
Posted : 17/07/2015 7:40 am
If you're looking to find the most popular routes in a given area you want to be using the strata heat map.
Posted : 17/07/2015 7:45 am
gpsies is pretty nice
Posted : 17/07/2015 8:09 am
bookmarked
Posted : 17/07/2015 9:09 am
 DT78
Strava without doubt the best tool. Either, use the route planner yourself and it will point out segments so you can see the popular areas (popular usually equals good outside of a conurbation), or find a segment or 2 with the explore function, look at the leaderboards, select one of the top 10 riders. Likely they will be a local fast boy and they will have done the time as part of a well trodden route. Copy route and either base your planning off it, or just export it as is. I've been using this method to learn my way round the South Downs.
Posted : 17/07/2015 10:08 am
