Rotors for Shimano ...
[Closed] Rotors for Shimano brakes
[#2418296]
Does anyone know of a good 180mm rotor that works well with Shimano XT Brakes, and that is hopefully cheaper than the proper XT rotor? A few months ago I changed the front from 160 to 180, got a Clarks rotor, and ever since I get a pulsing through the brake, so want to try another one to see if it stops the problem.
Posted : 30/01/2011 4:27 pm
Superstar rotors are good and very cheap. Only six bolt fitting though.
Posted : 30/01/2011 4:29 pm
6 bolt is what I want, have you used them with Shimano brakes?
Posted : 30/01/2011 4:40 pm
ebay has loads of disks of all sorts of cool shapes, prices and sizes. And yes, I've used them with shimano disks no problems.
Posted : 30/01/2011 4:42 pm
Yeah, they work well with my Deore brakes.
Posted : 30/01/2011 4:45 pm
 wes
I've got superstars on my XT's. They work fine (although the fronts started squealing woth superstars sintered pads I've just fitted)
Posted : 30/01/2011 4:46 pm
I shall give them a go, what design are you all using, I like the look of the Flame, do these work okay?
Posted : 30/01/2011 5:00 pm
Dont use superstar flames with xt! the cause real bad fork judder
see here:
http://www.singletrackworld.com/forum/topic/problems-with-superstar-flame-design-rotors
Well they did in my experience anyway
Posted : 30/01/2011 5:14 pm
Might try the Vibe style then, no pointy bits!
Posted : 30/01/2011 5:41 pm
They damage your forks as well? I love this place.
Posted : 30/01/2011 6:02 pm
???? I didn't say they damaged my forks! Just thought that the saw tooth design might be the cause of the judder, as the Clarks rotor I have are of a similar design. Wondered if the 'pointy' bits were somehow catching slightly due to the pad shape or something.
Posted : 30/01/2011 6:05 pm
Sorry, I was talking about the last post on the other thread, the one linked above -
ive now bought a set of elixir r brakes and rotors but my main concern is if the juddering as effect on my forks because i ran them for some time before realizing how bad they were.ive had expensive forks that have devoloped play and become flexy!
Posted : 30/01/2011 6:13 pm
Ahh okay 🙂
Posted : 30/01/2011 6:15 pm
