Rotor fitting washe...
[Closed] Rotor fitting washer - do I need one?
 PJay
[#7147941]
I've just bought a new set of wheels and thought that I'd replace my rotors at the same time.
I've bought plain steel (single piece, so no aluminium spider) Zee 6 bolt rotors to replace my old XT one. Previously I've just bolted the rotors straight to the hub but the instructions show a washer that appears to be circle of metal cut to sit under the head of the rotor bolts; all I have in the packaging are the rotor bolts and the silly little Shimano fold over clips (which I've never used.
Do I need this washer or can I just bolt the rotors straight to the hubs as I've always done?
Posted : 22/06/2015 6:42 pm
Never heard of them, might be something new.
Only ever used the shimano fold over tabs, can't imagine how they'd be much use under the bolts heads anyway, got a photo of them?
Posted : 22/06/2015 7:23 pm
I think they ship a big washer with new cassettes, it's about 3mm thick 😉
Posted : 22/06/2015 7:42 pm
I've seen something similar, I thought it was designed to space out the rotors on a second set of wheels so you can swap wheels without adjusting the caliper.
Posted : 22/06/2015 7:51 pm
